May 29, 20224 yr I am running the latest unraid 6.10.2 This is my first time setting this up. I have always just put my passphrase in manually. I created my keyfile and it will start my array. I also setup a ftp server. I created my fetch_key and it works if I run it in terminal. I created my delete_key and it works if I run it in terminal. I added the following to my go file. #!/bin/bash # auto unlock array mkdir -p /usr/local/emhttp/webGui/event/starting mkdir -p /usr/local/emhttp/webGui/event/started mkdir -p /usr/local/emhttp/webGui/event/stopped cp -f /boot/custom/bin/fetch_key /usr/local/emhttp/webGui/event/starting cp -f /boot/custom/bin/delete_key /usr/local/emhttp/webGui/event/started cp -f /boot/custom/bin/fetch_key /usr/local/emhttp/webGui/event/stopped chmod a+x /usr/local/emhttpd/webGui/event/starting/fetch_key chmod a+x /usr/local/emhttpd/webGui/event/started/delete_key chmod a+x /usr/local/emhttpd/webGui/event/stopped/fetch_key # Start the Management Utility /usr/local/sbin/emhttp & and this is where I'm stuck. I get the following when I restart chmod: cannot access '/usr/local/emhttp/webGui/event/starting/fetch_key' : No such file or directory chmod: cannot access '/usr/local/emhttp/webGui/event/started/delete_key' : No such file or directory chmod: cannot access '/usr/local/emhttp/webGui/event/stopped/fetch_key' : No such file or directory
