Possible FS corruption or Permission Problem
Been having issues where my containers aren't working (ie. radarr not talking to deluge). Fix Common Problems says the cache is read only.
Any ideas?
tower-diagnostics-20220614-1923.zip
Have you done memtest?
I have not, what's the best way to do that?
Jun 14 14:55:21 Tower kernel: BTRFS info (device sdi1): bdev /dev/sdj1 errs: wr 772370105, rd 641390571, flush 4473716, corrupt 4949264, gen 0
Jun 14 14:55:21 Tower kernel: BTRFS info (device sdi1): bdev /dev/sdi1 errs: wr 1603125, rd 1089630, flush 8890, corrupt 3731, gen 0
Both cache devices are showing a very large number or read and write errors, this means both have been dropping offline, see here for better pool monitoring.
This could be related to the UDMA CRC errors, I've tried replacing the SATA cables on them, but they keep coming back.
That can't be just from CRC errors, devices are dropping offline, but bad enough CRC errors/cable issue can result in disks dropping.
