Problem with Docker and Azure Container Registry
I am currently trying to setup a test environment for some apps.
My plan is to publish from my local device to ACS (Azure Container Registry) and then have it updated on UnRAID.
So far, i was able to setup an SPN to then login and get the image using Docker's UI.
The problem comes while updating. I've been pushing some images to the ACS, but i can't force it to update.
Any idea of what can i be doing wrong ?
Edit: Doing a manual docker pull updates the image. Still not showing on the UI.
Edited by Tom Morello
Update
