Running a VM with a wireless monitor adapter?
Hello Friends,
I'm a novice UnRAID user. Until now I used UnRAID to install and use various docker services.
Now I would like to use my server for a VM and I would like to use it with a wireless monitor on my work desk that is located a couple of meters away from the PC running the UnRAID server (there's no possibility to run an HDMI cable from the server to the monitor).
Is that possible?
Can anyone recommend a wireless display adapter for this or a monitor with built-in wireless connection support?
Is there a preferable OS to achieve this goal: MacOS, Windows, Linux?
Is there a good tutorial that explains how to install VM's?
Thank you very much for all your help.
