3WARE 8506 not supported or configuration problem ? please help...
I'm running this controller with 2 maxtor 160G in RAID 1 configuration.
I've created the array in the raid card bios, then I tried to run UNRAID, and once I went into the web management console the drives are not shown at all...  :-[ :-[ :-[
I tried to erase the array and boot up again but the situation didn't change.
I sincerly don't know what shall I try now... Has anyone some advice ?
Below my configuration:
MB: EPIA miniITX MII 1200
RAM: 512Mb infineon
controller: 3WARE RAID 8506 lp4
disks: MAXTOR diamond MAX20 160Giga 2mb cache
boot: 256 CF running on CF2IDE adapter.
Thanks in advance
Right, unRAID does not support any RAID card drivers.  Go into the bios of your RAID card and set it up for JBOD mode.
