July 13, 20224 yr Hello. I have installed a new NIC card in my Unraid server. After the installation I couldn't connect to unraid GUI with the networkcable connected to my motherboard. So I tried to connect the networkcable to the new installed NIC-card and it worked. I think i got a error message "cannot find eth0" <- I think that this was the message.. Now. I removed the secondary NIC from the motherboard but I still couldn't connect to unraid GUI throught the motherboard NIC. I had to deactivate VT-x in order to get the unraid gui work again. My question is, how do i connect to my motherboard nic with VT-x enabled and have my secondary NIC set to eth1? The reason I want a secondary NIC is because I want to run my cctv cameras on a separated network. /Emil (Sorry for the spelling and poor word choises) Posted this in wrong forum? Edited July 13, 20224 yr by gevsan Think I posed this in the wrong forum?
July 13, 20224 yr Community Expert 7 minutes ago, gevsan said: I had to deactivate VT-x in order to get the unraid gui work again. Which Unraid release are you running?
July 13, 20224 yr Author 12 minutes ago, JorgeB said: Which Unraid release are you running? 6.10.3 Edited July 13, 20224 yr by gevsan
July 13, 20224 yr Community Expert Pleas post the diagnostics, if you cannot access the GUI you can type diagnostics on the console.
July 14, 20224 yr Author 21 hours ago, JorgeB said: Pleas post the diagnostics, if you cannot access the GUI you can type diagnostics on the console. Here it is. I can access the GUI since I disabled VT-X in Bios. But right now I cannot remember if I removed the 2nd NIC from the motherboard or not... I will have to check and see if it's in when im home. tower-diagnostics-20220714-1011.zip
July 14, 20224 yr Community Expert Now enable virtualization and post new diags when the NIC doesn't work.
August 7, 20224 yr Author Hello again. Sorry for the late reply.. Once i type "diagnostics" in the console, how do I access it to post it here?
August 7, 20224 yr Community Expert 1 hour ago, gevsan said: Hello again. Sorry for the late reply.. Once i type "diagnostics" in the console, how do I access it to post it here? It will be put into the logs folder on the flash drive. You can either access that via Unraid or by temporarily plugging the flash drive into a PC/Mac
August 14, 20224 yr Author Hey again. I finaly had a oppertunity to test this. I enabled virtualization in BIOS again and now I can connect to my unraid server again. So everything is fine All I did was to remove the new NIC. When the time comes and I need to reinstall the NIC I might run into the same problem. But that will be a new topic..
August 15, 20224 yr @gevsan - It's interesting that we both ran into the same issue around the same time. This is my second attempt at trying to get the NIC to work. My thread. Edited August 15, 20224 yr by rockbox948
