August 9, 20224 yr Hello there! How are you? Look, I install unraid a few days ago for first time on my device and before to buy the software. I need a hand with your experience and knowledge about a few things, please. 1. It's possible to work with SSL effectively. Like when you open a web page with SSL working and securely. ? If that is possible, how can I do it? Is there any tutorial step by step or someone can tell me how to do it, please? 2. Under the section of: User Shares I noticed the following directories appearing in orange color app data domains system And say some or all files unprotected. Can I secure these directories? How can I do it? Is there any tutorial step by step or someone can tell me how to do it, please? 3. Under the section of: User Shares I create a share with a name, after in SMB Security Settings I chose “Private” and also try with “Secure” Then in SMB User Access, I select my user and chose read and write. But from my MAC and my PC. I can't enter to that share I create. I try with smb://IP/Folder Share smb://IP smb://Name of my server /Folder Share http://IP/Folder Share http://IP http://Name of my server /Folder Share. But I can't log in. I can't enter to my folder share. How can I do it? Is there any tutorial step by step or someone can tell me how to do it, please? 4. Under the section of: Virtual Machines When I want to add a VM, for example select Windows o Linux And in the part of OS Install ISO: I click there and nothing happen, don't show me anything. So, I try to drop there the image ISO from my desktop, but doesn't work. How can I do it? Is there any tutorial step by step or someone can tell me how to do it, please? Currently, that's all. Thanks to all in advance. Cheers.
August 9, 20224 yr 1. Settings>Management Access>provision certificate will create a let’s encrypt ssl certificate. 2. You would need to use a cache pool raid. This is not a replacement for a good backup though. https://m.youtube.com/watch?v=jgRSr7yBZfs
August 9, 20224 yr Author @wgstarks Thanks for your answer. But you know in relation with my question number 1. I did that and also activate the SSL. But my browser say the connection is insecure. How can I make it secure? About my question number 2. I will watch the video and tell you later. Finally, about my other questions. If you, or anybody else, can give me a hand. I will be eternally grateful. Thanks a bunch. Cheers.
August 9, 20224 yr 2 hours ago, DeepSable said: But my browser say the connection is insecure. How can I make it secure? Are you using the lets encrypt address shown on the settings pane to connect to your server? It will be something like https://<server IP>.<multiple random alpha numeric digits>.myserver.net. For number 3, what happens if you try to connect just to the IP without including the share name. You should probably attach your diagnostics to your next post.
