NCT6775 & Dynamix System Temperature + Dynamix Auto Fan Control Support
15 hours ago, K1ng0011 said:
Yah I saw that as an option also. Unfortunately I live in the US and due to reasons (tariffs) the creator of the open fan is currently not selling to US customers. So this is not an option currently for me.
Bummer...
If you can get one pwm fan header to work, then split it and use this https://www.amazon.com/Thermalright-Integrated-10-Port-Controller-Support/dp/B09CH31RM6/
If not then maybe CORSAIR iCUE COMMANDER CORE XT
Neither worm as good as an OpenFan
Or better yet, see if you can find an OpenFan used...
Or maybe have it to delivered to a friend somewhere else, maybe Mexico or Canada, then go pick it up from there...
Or order it for hotel delivery on your next business or hotel trip.
  • 3 months later...
  • Replies 106
  • Views 55.6k
  • Thanks for you greate step-by-step guide Works for ASUS W680-ACE
  • You need to install this and reboot afterwards:   (please keep in mind that this is not related to this thread because NCT chips are completely different).
  • It seems that it cannot load correctly due to the drivers for the Kraken not being part of the OS. Looking at others online, Kraken AIOs seems to be very sporadically supported on Linux and many optin
i dont know if this is a good place to look for help.
Hello .. been playing around with the IPMI and I can not under understand. I don't seem to be able to edit anything. the IPaddress is there and i have entered the username and password. I know the username and password it good.
I am using a SuperMicro :
Supermicro X9QR7-TF+/X9QRi-F+ , Version 123456789
American Megatrends Inc, Version 3.0a
BIOS dated: Thu 3 Apr 2014 12:00 AM
No sure will it work with my computer setup. i have looked for any fan drivers from supermicro but could not find anythihng yet, if not any thoughts.
Thanks John G.
Thanks John G.
Not really the right place, but I know Supermicro boards can be a b* because their fan control runs through the BIOS and ipmi commands.
What you could try to do is:
Run lm-sensors to see if it works
Then run fancontrol to see it works now
If it does then try to not use Dynamix but the new FanControl Plus https://forums.unraid.net/topic/191722-plugin-fancrtl-plus
If this all fails and you want actual control, you're better off with a fan controller like OpenFan.
Sorry couldn't be of
more help!
  • 2 months later...
Hello,
I am having weird issues with PWM, and fan speed sensors. I expect it is related to the drivers. How to find out which driver I need to use? System temp plugin detects it87 k10temp. However I am having weird issues.
I have 3 fans connected on different mobo headers. Sys fan 1,3, CPU. Issues:
  1. Unraid only detects fan speed for sys fan 3.
  2. PWM control only works at 1000 - 1700 rpm. Fan does not slow down bellow 1000 rpm.
Mobo: Gigabyte aorus b550 v2
I expect that my issues are due to wrong drivers?
I'd like to be able to see all 3 of my fans and have my case fans spin up only when my disks are active... FanCtrl plus seems perfect for this task yet my fans do not spin down bellow 1000 rpm...
pwmconfig command returns the folowing:
Found the following devices:
   hwmon0 is acpitz
   hwmon1 is k10temp
   hwmon2 is nvme
   hwmon3 is nvme
   hwmon4 is nvme
   hwmon5 is it8792
Found the following fan sensors:
   hwmon5/fan1_input     current speed: 0 ... skipping!
   hwmon5/fan2_input     current speed: 0 ... skipping!
   hwmon5/fan3_input     current speed: 1695 RPM
Testing pwm control hwmon5/pwm3 ...
  hwmon5/fan3_input ... speed was 1695 now 1136
    It appears that fan hwmon5/fan3_input
    is controlled by pwm hwmon5/pwm3
Would you like to generate a detailed correlation (y)? y
    PWM 255 FAN 1358
    PWM 240 FAN 1149
    PWM 225 FAN 1083
    PWM 210 FAN 1053
    PWM 195 FAN 1040
    PWM 180 FAN 1036
    PWM 165 FAN 1027
    PWM 150 FAN 1022
    PWM 135 FAN 1022
    PWM 120 FAN 1019
    PWM 105 FAN 1018
    PWM 90 FAN 1018
    PWM 75 FAN 1019
    PWM 60 FAN 1021
    PWM 45 FAN 1016
    PWM 30 FAN 1010
    PWM 28 FAN 1008
    PWM 26 FAN 1018
    PWM 24 FAN 1019
    PWM 22 FAN 1016
    PWM 20 FAN 1011
    PWM 18 FAN 1010
    PWM 16 FAN 1002
    PWM 14 FAN 1016
    PWM 12 FAN 1016
    PWM 10 FAN 1013
    PWM 8 FAN 1010
    PWM 6 FAN 1007
    PWM 4 FAN 1004
    PWM 2 FAN 1005
    PWM 0 FAN 1011
And sensors output:
root@DataServer:~# sensors
nvme-pci-0100
Adapter: PCI adapter
Composite:    +31.9°C  (low  = -273.1°C, high = +84.8°C)
                       (crit = +84.8°C)
Sensor 1:     +31.9°C  (low  = -273.1°C, high = +65261.8°C)
Sensor 2:     +26.9°C  (low  = -273.1°C, high = +65261.8°C)
nvme-pci-0400
Composite:    +32.9°C  (low  =  -0.1°C, high = +74.8°C)
                       (crit = +79.8°C)
acpitz-acpi-0
Adapter: ACPI interface
temp1:        +16.8°C
it8792-isa-0a60
Adapter: ISA adapter
in0:           1.79 V  (min =  +0.00 V, max =  +2.78 V)
in1:         589.00 mV (min =  +0.00 V, max =  +2.78 V)
in2:           1.04 V  (min =  +0.00 V, max =  +2.78 V)
+3.3V:         3.38 V  (min =  +0.00 V, max =  +5.56 V)
in4:           1.79 V  (min =  +0.00 V, max =  +2.78 V)
in5:           1.50 V  (min =  +0.00 V, max =  +2.78 V)
in6:           2.78 V  (min =  +0.00 V, max =  +2.78 V)  ALARM
3VSB:          3.36 V  (min =  +0.00 V, max =  +5.56 V)
Vbat:          3.23 V
Array Fan:   1018 RPM  (min =    0 RPM)
temp1:        +34.0°C  (low  = +127.0°C, high = +127.0°C)  sensor = thermistor
temp2:        -55.0°C  (low  = +127.0°C, high = +127.0°C)  sensor = thermistor
temp3:        +34.0°C  (low  = +127.0°C, high = +127.0°C)  sensor = thermistor
intrusion0:  ALARM
nvme-pci-0500
Composite:    +35.9°C  (low  =  -0.1°C, high = +74.8°C)
                       (crit = +79.8°C)
ERROR: Can't get value of subfeature temp2_min: I/O error
ERROR: Can't get value of subfeature temp2_max: I/O error
Sensor 1:    -226.2°C  (low  =  +0.0°C, high =  +0.0°C)
ERROR: Can't get value of subfeature temp3_min: I/O error
ERROR: Can't get value of subfeature temp3_max: I/O error
Sensor 2:    -239.2°C  (low  =  +0.0°C, high =  +0.0°C)
ERROR: Can't get value of subfeature temp4_min: I/O error
ERROR: Can't get value of subfeature temp4_max: I/O error
Sensor 3:    -237.2°C  (low  =  +0.0°C, high =  +0.0°C)
k10temp-pci-00c3
CPU Temp:     +34.2°C
MB Temp:      +32.0°C
Any tips as to what I should look into?
  • 2 months later...
On 10/26/2025 at 3:11 AM, Laov said:
  1. PWM control only works at 1000 - 1700 rpm. Fan does not slow down bellow 1000 rpm.
The RPM of a fan it's driven by it's design. Not all of them go down to low or zero RPM. I am dealing with this today, got numerous that would not go below 750rpm. Without restarting the system or changing any settings,I swapped it for Noctua NF-P12 redux-1300 PWM and it manages to drop to 0 RPM. That fan spec specifically says from 0 RPM, that is why I bought it. Many other models don't go down to zero.
Typical CPU fans, especially the cheap ones bundled with CPU have about 1000RPM minimum. Also, the higher the power/max RPM, the lower the chances it will spin down to zero RPM.
I do see that you have a chip it8792 - this is what lead me to this post. I have the same chip controlling 3 of my 6 fans and I can't get it to control speed at all thru unRaid 9but they do report RPM). My other 3 are on it8688 and I have full control of them
Edited by OrdinaryButt
I know the limitations of fan RPM and I know it is not the case as the same fans were plugged on different headers yielding different results. Issue was due to it8792 chip and its implementation on unraid. I just switched to a header that is on it8688 which solved all of the issues. So most likely case is that the driver has an issue with this chip.
Regarding fan speed not displaying - apparently playing around with PWM causes issues with the driver which in turn can brick systemp temps plugin from loading the proper driver to display RPM. System restart usually fixes that...
Anyway summary for PWM on unraid - pray that it works and don't touch it if it does. If it does not - 1st try server restart.
Edited by Laov
  • 7 months later...
For me below steps worked flawlessly to have Asus Z890 Plus Wifi drivers recognized on Unraid, and mobo, fan, etc., sensor data read.
Unraid terminal
sensors
Then
grep -H . /sys/class/hwmon/hwmon*/name
Then
sensors-detect
For sensors-detect, press Enter to accept the recommended/default answers. At the end, it should report something resembling:
Trying family `VIA/Winbond/Nuvoton/Fintek'... Yes
Found unknown chip with ID 0xd806
(logical device B has address 0x290, could be sensors)
Take a note of force_id 0xd806
Driver nct6775
Chip Nuvoton NCT6799D
The name of the chip may differ. Don’t modify /boot/config/go or add acpi_enforce_resources=lax yet, the latter is an older workaround with potential side effects.
Input
modprobe nct6775
sensors
Result
nct6798-isa-0290
SYSTIN: +32.0°C
CPUTIN: +44.0°C
AUXTIN0: +30.0°C
fan1: 700 RPM
fan2: 500 RPM
Unraid Terminal
grep -n "nct6775" /boot/config/go
Then
nano /boot/config/go
In the new window, add this line below #!/bin/bash:
You have your force_id from above previous codes
modprobe nct6775 force_id=0xd806
Save with:
Ctrl+O → Enter → Ctrl+X
Edited by Pegasbur
