September 19, 20224 yr Hello everyone, I'm using a HM90 Minisforum, and yesterday I noticed that my device is inaccessible. No ping response, unpaid web panel is inaccessible and also all my containers and VMs are not available. Then I upgraded to the newest beta version of unraid in hope that that issue solved. I did it yesterday and few minutes ago same issue happened again. I cannot access, seems to be crashed. HDMI Output is nothing, no console, nothing I can see. In fact, there is no output. I really don't know where I should look to find what the issue is, I hope people can help me at this point to figure out what happens and solve it. Thank you. #added diagnostics. I made this after cash on first boot. minisforum-diagnostics-20220919-1252.zip Edited September 19, 20224 yr by DerEchte added diagnostics
September 19, 20224 yr Community Expert Start here: https://forums.unraid.net/topic/46802-faq-for-unraid-v6/?do=findComment&comment=819173
September 20, 20224 yr Author Hello JorgeB, Your guide helps me to solve it. My solution was to disable C-States globally on bios. I didn't find any power supply idle settings, so that was my solution. Thank you!
October 21, 20223 yr Author Somehow, server crash again after a period of 14 days. It happened twice. Disabling C-States helps definitely, but still not stable. minisforum-diagnostics-20221021-1735.zip
October 21, 20223 yr Community Expert Enable the syslog server and post that after a crash to see if there's something visible.
October 30, 20223 yr Author On 10/21/2022 at 5:42 PM, JorgeB said: Enable the syslog server and post that after a crash to see if there's something visible. is the syslog in -> /boot/logs ? if yes i can not see there any issue. -> 22:51 i started the machine again. because it crash again syslog
October 31, 20223 yr Community Expert Nothing relevant logged that I can see, that usually points to a hardware problem, one thing you can try is to boot the server in safe mode with all docker/VMs disable, let it run as a basic NAS for a few days, if it still crashes it's likely a hardware problem, if it doesn't start turning on the other services one by one.
November 2, 20223 yr Author On 10/31/2022 at 10:36 AM, JorgeB said: Nothing relevant logged that I can see, that usually points to a hardware problem, one thing you can try is to boot the server in safe mode with all docker/VMs disable, let it run as a basic NAS for a few days, if it still crashes it's likely a hardware problem, if it doesn't start turning on the other services one by one. This error appears after 14 days, waiting 14 days in safe mode is quite LONG. Maybe I can do a 48h benchmark or something? Can you something others recommend to me? Edited November 2, 20223 yr by DerEchte
November 3, 20223 yr Community Expert You can run memtest for 24H, but that mostly tests RAM and it's only conclusive if it finds errors.
January 19, 20233 yr Author Disabling C-States does not solve my issue. After that i contacted Minisforum and they told me the following: "If you are using a linux system, you need to disable the IOMMU in the bios; Then we recommend installing the latest version of the linux system to use." Now I need to wait up to two weeks to confirm if it helps. But now my machine cannot use full of 1Gbit, speedtest is giving me around 120 Mbit instead of 1Gbit network speed.
