Jump to content
6.11 upgrade problem no drives or ethernet
KeeWay
Just tried upgrading from 6.9.2 to 6.11 and for some reason it looks like none of my PCI devices are being detected when it boots up because there is no drives or ethernet but I was able to login into the unraid box on 6.11 directly and get the diagnostics. I have provided diagnostics for non working 6.11 (tower-diagnostics-20220928-1303.zip) and the working 6.9.2 (nas-diagnostics-20220929-1146.zip).
My motherboard is the Intel Server Board S2600CP2J and the network card is the Intel Pro 1000 server adapter.
Is my board too old maybe? Any help is appreciated.
Thanks
James
nas-diagnostics-20220929-1146.zip tower-diagnostics-20220928-1303.zip
Link to comment
5 hours ago, KeeWay said:
is virtualizing unraid no longer supported then?
Virtualizing Unraid has never been supported. It's not forbidden, but it's always been, "if it works, great, if not, it's up to you to figure out how to make it work"
If you can figure out what needs to be changed to get it working again, and that change won't break things for people NOT virtualizing Unraid, then there is a high likelyhood that your fix will be included.
Link to comment
  Only 75 emoji are allowed.
  • Create New...
