unraid 6.11 problem with VMs and virbr0, no IP to external and noVNC
Hello Forum,
after adding a 2nd NIC and changing the MAC address of this NIC to eth0, there is no virbr0 mapping to the LAN network. Of course I played a lot with all related network settings and now I´m lost in space. I also tried to change the nic to the default eth0 mac but still the same behavior. Please can someone guide me to solve the problem?
Thank´s
mediatower-diagnostics-20221009-1442.zip
Solved by dremeier
I solved the Problem:
Shutting down the unraid server and edit the USB-Stick in a windows machine.
Removed the file /config/network-rules.cfg and edit the file /config/network.cfg to default values:
# Generated network settings
USE_DHCP="yes"
IPADDR=
NETMASK=
GATEWAY=
BONDING="yes"
BRIDGING="yes"
Now the routing of virbr0 is working as it should and noVNC is working as well.
