November 23, 20223 yr Evening! I've put off upgrading my Unraid server for a long time but I don't want to fall so behind that eventually I will be out of range for docker updates and unraid features in the future. It's been an entire year plus! I restored my system back to 6.9.2 after a failures of my Array to start. I let the system sit idle for 2-3 hours and nothing still. I had access to my plugins but my Docker programs wouldn't start and my "Array Status" bar in the bottom left of Unraid just stayed saying "Array Starting". I'm not good at reading errors but these are my conclusions and I hope to get some help from Moderators or other Unraid experts. 1 ) The Errors I'm see state that the Hard Drives of my array were an ID (Example: sdm) and are being changed to another (Example: sdam). Nov 23 15:08:08 XXXXXX emhttpd: error: hotplug_devices, 1730: No such file or directory (2): Error: tagged device N0008-2JJ101_SM_ZPW0LXZ5_3500605ba008bdc44 was (sdau) is now (sdw) Nov 23 15:08:08 XXXXXX emhttpd: error: hotplug_devices, 1730: No such file or directory (2): Error: tagged device WD100EMAZ-00WJSM_JEGKN5EN_3500605ba000a7138 was (sdab) is now (sdd) These hard drives are working just fine and are healthy. I'm not sure why this is happening. When reverting back to 6.9.2 the array starts up within 4-5 seconds of clicking on the button. 2 ) I have Errors stating they have problem getting the id. (May correlate to the error above) Nov 23 15:08:08 Khaleesi emhttpd: device /dev/sdi problem getting id Nov 23 15:08:08 Khaleesi emhttpd: device /dev/sdam problem getting id Nov 23 15:08:08 Khaleesi emhttpd: device /dev/sdp problem getting id Nov 23 15:08:08 Khaleesi emhttpd: device /dev/sdad problem getting id Again everything is working just fine on 6.9.2. 3) I have no clue what a segfault is but this is the last Error. Nov 23 15:08:08 Khaleesi kernel: emhttpd[11587]: segfault at 674 ip 00005584e01539d4 sp 00007fffadd01270 error 4 in emhttpd[5584e0141000+21000] I would appreciate as much help as possible. I attached the syslog file and diagnostic file from the 6.11.2 update to the post. khaleesi-diagnostics-20221123-1622.zip khaleesi-syslog-20221123-2120.zip
November 24, 20223 yr Nov 23 15:07:27 Khaleesi emhttpd: device /dev/sdk problem getting id Nov 23 15:07:27 Khaleesi emhttpd: device /dev/sdy problem getting id These usually mean the same devices are being detected twice, do you have more than on cable connecting the HBA to the NetApp enclosure?
November 24, 20223 yr Author The NetApp does. I have a cable for the bottom half of the NetApp connected to the HBA and a cable for the Top half connected to the 2nd port of the HBA. When I saw the enclosure had two separate sections on the whole enclosure, I assumed I had to do it that way. It's been working since 2020. Is there a reason for it stopping with the new update???
November 24, 20223 yr Author I'm gonna give this a shot! I know this is a stretch of an ask, but do you believe I should unplug the bottom cable and keep the top one in? lol
December 27, 20223 yr Author Thanks @JorgeBI appreciate you man! I shut it down, pull the cord from IOM2 and updated it to 6.11.5 from 6.9.5. BEAUTIFUL!!!!! Thank you so much!
