Web gui not working after power lose
So my unraid server lost power due to a power cut. I can connect to the SMB shares so I think that means the array is atleast starting.
But the web ui isnt connecting as well as the docker containers and plex can't connect either.
I've also connected a keyboard mouse and screen to the unraid server, launched in gui mode. And Linux launched but it says unable to connect to localhost in the browser
Edited by Sally-san
Extra infomation
Solved by JorgeB
Please post the diagnostics, you can get them from the console.
Your go file is incomplete, add to the beginning:
#!/bin/bash
# Start the Management Utility
/usr/local/sbin/emhttp &
And reboot
So that didnt work.
I'm not sure if I edited the right file.
I edited /boot/config/go
The file now looks like this
#!/bin/bash
/user/local/sbin/emhttp &
#Adjusting ARC memory usage (limit 1GB)
echo 8589934592 >> /sys/module/zfs/parameters/zfs_arc_max
I've attached updated logs
tower-diagnostics-20221125-1242.zip
Look like it's not correct since it's removing that line from the diags and emttp is still not starting, extract the default go file from a download zip and use that one.
I misspelt "usr" as "user" in the go file.
Its fixed, I'm so happy I could kiss you thank you for the help
