How to control FAN speed on CPU watercooler?
Is there an option to control the FAN speed of my CPU watercooler?
- Corsair H115i RGB Platinum
I see the Corsair H115i RGB Platinum in the VM settings, but when I activate it, I can't see it in Windows.
I installed also the libvirt hotplug plugin but nothing is happening.
The iCue software on my Windows VM doesn't detect the Corsair H115i RGB.
Does anyone have a similar setup?
If this is not feasible with Unraid. Can anyone recommend a hardware controller where I can control the CPU water cooler fans externally?
Thanks!
