December 9, 20223 yr I am new to the unraid, there is my problem, do i having a bad drive or what. this server is up for only 3 days, and i was only trying to back up the data from external drive and under below is my disk management setting :
December 9, 20223 yr Author in addition, at the beginning(right after the first boot), i was using the tool (new config) several times, because I was missing a drive(it was connected via SATA, but it does not show on the Unraid web GUI), and I rebooted few times, each time i use the tool (new config (ps i did not save older version of the config)). hope this information might help to understand my issue. in conclusion, i have 2 issues: 1. slow parity check (takes few years to finish) 2.slow file transfer speed from cache to array (around 3MB/s) 3. so many error showed on parity drive.
December 9, 20223 yr Community Expert You are likely to get better informed feedback if you attach your system’s diagnostics zip file to your next post in this thread.
