Help - Move Docker container to other drive?
Hey fellas!
So I have a gameserver running on my Unraid machine... unfortunately I've installed it on a HDD and now my server is laggy whenever I play with friends (Satisfactory).
Is there a way to move the Docker from my HDD to my SSD?
Thank you!
If you mean the docker image you can just recreate it on a different device, you also move the appdata folder there if you want using for example the mover, docker service must be disabled first.
