Containers running very slow and constantly losing connection
Can someone take a look at my diags and tell me if there are any glaring issues. My container just recently started running really slow and are constantly losing connectivity. Thanks.
diagnostics-20221220-2119.zip
Solved by rodericklm
Noting obvious in the log that I can see but server load is very high, try rebooting.
Thanks, a reboot did not fix the issue, but I did a BTRFS scrub with "correct file system errors" and that seemed to have fixed the issue.
