December 23, 20223 yr I recently have have experienced a problem with my flash drive "dropping offline", i.e. I can't access the Unraid web gui from my Windows 10 VM. The VM keeps working fine but the shares are unreachable via the network. Shutting down and restarting solves the problem. I've attached diagnostics and the last log from my log server. Any advice? Thanks and Happy Holidays!syslog-192.168.0.190.logsyslog-192.168.0.190.logsyslog-192.168.0.190.log tower-diagnostics-20221223-0707.zip syslog.zip
December 23, 20223 yr Community Expert Make sure it's using a USB 2.0 port, if the problem persists try with a different flash drive.
December 26, 20223 yr Author On 12/23/2022 at 7:51 AM, JorgeB said: Make sure it's using a USB 2.0 port, if the problem persists try with a different flash drive. I switched the flash drive from a USB 3 port to a USB 2 port. I didn't even realize it was connected to a USB 3 port. So far so good. I have a backup USB flash drive just in case. Thanks for the reply.
