Lots of issues after power outage
The first thing that I noticed was that my uptime in the top right corner was way off. It's showing an uptime of 11 years when I just restarted it. Another thing is that all my dockers are showing version not available. If I go to update OS that also shows not available. Under apps it gives me "Download of appfeed failed". I tried changing my DNS and that did nothing to resolve it. I tried turning off wiregaurd as I saw that help someone else with the dockers but that did nothing. I pinged from the server my home router and it was fine, I pinged out to google (8.8.8.8) and it was fine. I didn't think it was really affecting things until I went to try and watch Plex and it wasn't showing up on any of my devices. So I'm at a loss here and don't know what to do to resolve this.
Solved by trurl
What date and time is it on your server?
I can't believe I didn't even think of this. I was way over thinking everything. Thank you so much for your help, everything seems back to normal now.
You might need to replace CMOS battery if it forgets the correct time.
