July 17, 201115 yr I'm getting parity errors all of a sudden. This is the second time that this is happening in 1.5 months. The only change that I made was adding a PATA 320gb 7200rpm cache drive, installing Plex and upgrading to an AMD X2 250 from a Sempron 140. Attached is my syslog. Please check and help me diagnose the problem. Thanks! Update: After doing a powerdown and startup, my array status was "Stopped. New parity disk installed." The weird part is the size being reported under device status is going up. Currently at 382.63 TB and growing??? Using Simple Features 0.7 Update 2: Further examination of the syslog, I also get "program smartctl is using a deprecated SCSI ioctl, please convert it to SG_IO" errors Update 3: I checked all the SATA cables and the cable on the parity drive was somewhat loose. I replaced the cable and did a parity rebuild. Completed successfully with no error. I then ran the mover script to move files from the cache and finished successfully. Currently running: unRAID 5.0-beta8d Biostar A760G M2+ AMS Athlon II X2 250 4GB Memory 6x 2TB 7200rpm HD 1x 320GB 7200rpm HD (PATA) Corsair HX Series CMPSU-520HX 520W Cooler Master Centurion 590 syslog-2011-07-17.zip
July 24, 201115 yr Author I thought I solved this issue but it came back two days ago. I removed my cache drive before I did a parity check thinking it is a power issue. Parity check completed with no errors but errors occurred in the syslog again today. I ran Smart Status report on my parity drive and although the SMART overall-health self-assessment test result returned as PASSED, it had a huge Raw_Read_Error_Rate. I will just replace the parity drive right now and do more test of the drive. ul 23 23:58:28 Frank-Server kernel: ata4.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x0 Jul 23 23:58:28 Frank-Server kernel: ata4.00: irq_stat 0x40000001 Jul 23 23:58:28 Frank-Server kernel: ata4.00: failed command: READ DMA EXT Jul 23 23:58:28 Frank-Server kernel: ata4.00: cmd 25/00:b8:97:e7:a0/00:00:3b:00:00/e0 tag 0 dma 94208 in Jul 23 23:58:28 Frank-Server kernel: res 51/40:57:e7:e7:a0/00:00:3b:00:00/e0 Emask 0x9 (media error) Jul 23 23:58:28 Frank-Server kernel: ata4.00: status: { DRDY ERR } Jul 23 23:58:28 Frank-Server kernel: ata4.00: error: { UNC } Jul 23 23:58:28 Frank-Server kernel: ata4.00: configured for UDMA/133 Jul 23 23:58:28 Frank-Server kernel: ata4: EH complete Jul 23 23:58:30 Frank-Server kernel: ata4.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x0 Jul 23 23:58:30 Frank-Server kernel: ata4.00: irq_stat 0x40000001 Jul 23 23:58:30 Frank-Server kernel: ata4.00: failed command: READ DMA EXT Jul 23 23:58:30 Frank-Server kernel: ata4.00: cmd 25/00:b8:97:e7:a0/00:00:3b:00:00/e0 tag 0 dma 94208 in Jul 23 23:58:30 Frank-Server kernel: res 51/40:57:e7:e7:a0/00:00:3b:00:00/e0 Emask 0x9 (media error) Jul 23 23:58:30 Frank-Server kernel: ata4.00: status: { DRDY ERR } Jul 23 23:58:30 Frank-Server kernel: ata4.00: error: { UNC } Jul 23 23:58:30 Frank-Server kernel: ata4.00: configured for UDMA/133 Jul 23 23:58:30 Frank-Server kernel: ata4: EH complete Jul 23 23:58:32 Frank-Server kernel: ata4.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x0 Jul 23 23:58:32 Frank-Server kernel: ata4.00: irq_stat 0x40000001 Jul 23 23:58:32 Frank-Server kernel: ata4.00: failed command: READ DMA EXT Jul 23 23:58:32 Frank-Server kernel: ata4.00: cmd 25/00:b8:97:e7:a0/00:00:3b:00:00/e0 tag 0 dma 94208 in Jul 23 23:58:32 Frank-Server kernel: res 51/40:57:e7:e7:a0/00:00:3b:00:00/e0 Emask 0x9 (media error) Jul 23 23:58:32 Frank-Server kernel: ata4.00: status: { DRDY ERR } Jul 23 23:58:32 Frank-Server kernel: ata4.00: error: { UNC } Jul 23 23:58:32 Frank-Server kernel: ata4.00: configured for UDMA/133 Jul 23 23:58:32 Frank-Server kernel: ata4: EH complete Jul 23 23:58:34 Frank-Server kernel: ata4.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x0 Jul 23 23:58:34 Frank-Server kernel: ata4.00: irq_stat 0x40000001 Jul 23 23:58:34 Frank-Server kernel: ata4.00: failed command: READ DMA EXT Jul 23 23:58:34 Frank-Server kernel: ata4.00: cmd 25/00:b8:97:e7:a0/00:00:3b:00:00/e0 tag 0 dma 94208 in Jul 23 23:58:34 Frank-Server kernel: res 51/40:57:e7:e7:a0/00:00:3b:00:00/e0 Emask 0x9 (media error) Jul 23 23:58:34 Frank-Server kernel: ata4.00: status: { DRDY ERR } Jul 23 23:58:34 Frank-Server kernel: ata4.00: error: { UNC } Jul 23 23:58:34 Frank-Server kernel: ata4.00: configured for UDMA/133 Jul 23 23:58:34 Frank-Server kernel: ata4: EH complete Attached is a syslog and smart status report of my parity drive. syslog-2011-07-24.txt Smart_info.txt
July 28, 201115 yr ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE 1 Raw_Read_Error_Rate 0x000b 089 089 016 Pre-fail Always - 4128782 This value looks fine. The VALUE is 089 which is well above the THRESH of 016. The RAW_VALUE only has meaning to the manufacturer. ata4=sde=disk3. Post a SMART report for sde.
July 28, 201115 yr Author Thank you for replying. I'm still monitoring this issue and so far has not returned in two days. Out of desperation, I swapped my power supplies from the Antec earthwatts 500 to my Corsair HX Series CMPSU-520HX. I also replaced my parity drive with a WD Black and moved added my old parity drive back in as Disk 6. Making a lot of changes does not really help diagnose the current issue I always thought ATA4 meant my cache drive which is PATA. Thanks for explaining the Smart report. So as the drive gets worse, the VALUE will get lower and closer to the THRESH value? Statistics for /dev/sde WDC_WD2001FASS-00W2B0_WD-WMAY00288742 smartctl -a -d ata /dev/sde smartctl 5.40 2010-10-16 r3189 [i486-slackware-linux-gnu] (local build) Copyright (C) 2002-10 by Bruce Allen, http://smartmontools.sourceforge.net === START OF INFORMATION SECTION === Model Family: Western Digital Caviar Black family Device Model: WDC WD2001FASS-00W2B0 Serial Number: WD-WMAY00288742 Firmware Version: 01.00101 User Capacity: 2,000,398,934,016 bytes Device is: In smartctl database [for details use: -P show] ATA Version is: 8 ATA Standard is: Exact ATA specification draft version not indicated Local Time is: Wed Jul 27 22:46:38 2011 EDT SMART support is: Available - device has SMART capability. SMART support is: Enabled === START OF READ SMART DATA SECTION === SMART overall-health self-assessment test result: PASSED General SMART Values: Offline data collection status: (0x84) Offline data collection activity was suspended by an interrupting command from host. Auto Offline Data Collection: Enabled. Self-test execution status: ( 0) The previous self-test routine completed without error or no self-test has ever been run. Total time to complete Offline data collection: (30060) seconds. Offline data collection capabilities: (0x7b) SMART execute Offline immediate. Auto Offline data collection on/off support. Suspend Offline collection upon new command. Offline surface scan supported. Self-test supported. Conveyance Self-test supported. Selective Self-test supported. SMART capabilities: (0x0003) Saves SMART data before entering power-saving mode. Supports SMART auto save timer. Error logging capability: (0x01) Error logging supported. General Purpose Logging supported. Short self-test routine recommended polling time: ( 2) minutes. Extended self-test routine recommended polling time: ( 255) minutes. Conveyance self-test routine recommended polling time: ( 5) minutes. SCT capabilities: (0x3037) SCT Status supported. SCT Feature Control supported. SCT Data Table supported. SMART Attributes Data Structure revision number: 16 Vendor Specific SMART Attributes with Thresholds: ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE 1 Raw_Read_Error_Rate 0x002f 200 200 051 Pre-fail Always - 334 3 Spin_Up_Time 0x0027 158 156 021 Pre-fail Always - 14066 4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 557 5 Reallocated_Sector_Ct 0x0033 200 200 140 Pre-fail Always - 0 7 Seek_Error_Rate 0x002e 200 200 000 Old_age Always - 0 9 Power_On_Hours 0x0032 093 093 000 Old_age Always - 5773 10 Spin_Retry_Count 0x0032 100 100 000 Old_age Always - 0 11 Calibration_Retry_Count 0x0032 100 253 000 Old_age Always - 0 12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 31 192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 4 193 Load_Cycle_Count 0x0032 199 199 000 Old_age Always - 4065 194 Temperature_Celsius 0x0022 114 109 000 Old_age Always - 38 196 Reallocated_Event_Count 0x0032 200 200 000 Old_age Always - 0 197 Current_Pending_Sector 0x0032 200 200 000 Old_age Always - 1 198 Offline_Uncorrectable 0x0030 200 200 000 Old_age Offline - 0 199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 0 200 Multi_Zone_Error_Rate 0x0008 200 200 000 Old_age Offline - 118 SMART Error Log Version: 1 No Errors Logged SMART Self-test log structure revision number 1 Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error # 1 Conveyance offline Completed without error 00% 0 - SMART Selective self-test log data structure revision number 1 SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS 1 0 0 Not_testing 2 0 0 Not_testing 3 0 0 Not_testing 4 0 0 Not_testing 5 0 0 Not_testing Selective self-test flags (0x0): After scanning selected spans, do NOT read-scan remainder of disk. If Selective self-test is pending on power-up, resume after 0 minute delay.
