Fix to a small issue with updating OCI docker images
Here, manual patching without script, is it OK?
  • Replies 144
  • Views 64.8k
  • HIGHLY recommended to NOT patch your docker files manually and instead use the plugin.  Patching manually means that if / when you update the OS to 6.12 any manually patches that you are applying auto
  • I have included your update for the next Unraid version. Thanks
  • The plugin will not install on 6.12+, so it's a install once, forget about it completely and you're safe going forward
THANK YOU Squid and everyone else that contributed to fixing this.  It had been driving me crazy for quite some time!!!
Zigbee2MQTT was the first one that started showing not available awhile back, then 2 more popped up in my list.
Thank you, worked for me. Using terminal and nano. I found the line, typed the change(added the extra), hit exit(ctrl+X) command, then Y to save and just hit enter again, no need to select append or prepend.
@Squid Not sure if the future UR update is going to handle this but there seems to be another issue where the "Update All" button will update containers that the UI says are up to date. I think the plugin patch solves the UI display but not the underlying update functionality.
Edited by aglyons
I believe it was stated that on reboot it gets overwritten, hence why it says not to use scripts. so if you changed it manually you can just install this plugin so it will do it for you and stop once you upgrade as it is made to work up to version 6.11.5 and not anything newer.
I'm not seeing that behaviour
Hello,
I had already manually installed the checkmk docker, before I install the docker.patch plugin. Now, Unraid continuously tells me that there is an update available for it. When I try to update it, I get this error: "Configuration not found. Was this container created using this plugin?". Is there any way to go back and create a configuration file for the plugin so I can upgrade it via Unraid?
I'll try to recreate this when a new update comes out for a container. Will post logs and screenshots if it does it again.
Anyone else got 'pending' for S3 sleep plugin?
It's probably stuck.  (and quite possibly due to some GitHub issues).
You should reboot and try again.
On 1/29/2023 at 12:49 AM, Squid said:
HIGHLY recommended to NOT patch your docker files manually and instead use the plugin.  Patching manually means that if / when you update the OS to 6.12 any manually patches that you are applying automatically will potentially interfere with the OS and be a big pain to troubleshoot
worked perfectly for me - thank you very much @Squid
i installed the plug in and restart the unraid server
but still the same issue
Just installed the patch and rebooted.
Glad I am not the only one with this problem. Same as @luckyheiko I cannot get updates.
Multiple reasons possible for still not seeing updates.  #1 would be internet connectivity (you can't reach docker hub)
#2 would be that the tag you're using on the container is no longer actually available on dockerHub
But I can still download and install all docker images and plugins in the app market. I don't only have issues requesting versions for docker, but also for plugins. If something on my network would block it, i'd seen it. I have not changed my network config for quite a while now. Only updated my unraid with all it's features that wanted to be updated.
After installing the patch plugin initially it was saying some images not available, but after "force update" on both of them updates have worked ever since. I would try doing force update.
to make it a little easier for those, one liner to copy+paste to update (and guarded so even if you run it multiple times it wont mangle the line)
sed -i "s#distribution.manifest.v2+json'#distribution.manifest.v2+json,application/vnd.oci.image.index.v1+json'#" /usr/local/emhttp/plugins/dynamix.docker.manager/include/DockerClient.php
Hey, I know it's likely not related to the docker patch... but ever since I installed this plugin, my internet keeps disconnecting on my unraid server. No other devices on the lan are losing internet. I can still ssh / access the web gui locally. I can get internet back up my doing a ping or some kind of web request, and then it'll get connectivity, but it loses it CONSTANTLY! This all started after I installed this plugin, though that doesn't mean it's the culprit. The worst part is that nothing is showing up in my logs... no eth0 / network events, so I can't even see what's causing it. I know everyone will be quick to point out my network, but my IPTV and mobile phones / main PC never lose internet. I am using the internet right this moment while the server has issues pinging 1.1.1.1.
Let me know if anyone has run into this.
This, see pic, has been made a part of "fix common problems' plugin too. Is installing the patch in this thread, plus whatever implementation "Fix Common Problems" has built in going to cause problems both being applied?
(I am assuming that's what this change-log is referring to?)
No.  I'm tired of answering the same questions about why update checks show up as unavailable so put a test into FCP to see if the plugin is installed and point you to it in Apps if it isn't
12 hours ago, Squid said:
Yeah, its not the plugin.
Check out this error, it's the first error to ever show...
Packet send failed to 10.0.0.255
Broadcast not working?
It's just strange because it's only my unraid server that fails, I have a continuous ping on my gaming pc and 2nd server (ubuntu), no problems there. It's driving me mad. I posted on reddit and one other person is having the same issue, but he's having trouble tracking down the origin. What can I do to get some help? Can I pay somebody?
Sorry— 🎶it’s me, I’m the problem, it’s me. I was just trying to confirm if this and the “Fix Common Problems” were going to conflict. 🥹
