Docker Crashed and Fix Common Problems Error (Solved)
My dockers crashed last night and woke up to none of them working.  Went to try and restart the docker and it won't restart.  Then I noticed I have an error from the Fix Common Problems app one for Unable to write to cache and the other unable to write to docker image.   Appreciate any help you guys can give me.
Thanks,
wazserver-diagnostics-20230123-0817.zip
Edited by TheIlluminate
Solved by JorgeB
For this error:
Jan 22 19:53:42 WazServer kernel: BTRFS error (device nvme0n1p1): block=721038295040 write time tree block corruption detected
You should run memtest since this is usually caused by a RAM problem, but a reboot should fix the current issue.
2 minutes ago, JorgeB said:
For this error:
Understood I guess its a good thing this mobo includes a memtest option.  Ill run that real quick and get back to you.  Thanks.
26 minutes ago, JorgeB said:
For this error:
Ran 2 passes through memtest 86 and 0 errors so I guess ill keep an eye on it and if it happens again...well RAM is cheap.
  • TheIlluminate changed the title to Docker Crashed and Fix Common Problems Error (Solved)
