October 19, 20251 yr I was going through the same issue, and tried to disable fastboot, enable/disable xhce handoff, enable/disable legacy USB support, etc. Nothing to prevent my USB boot drive to sometimes unrecognised from the BIOS, or booted to unraid just to then having errors (dev/sda check return "device descriptor read/64 error").You can try plugging your USB boot drive into the 2.0 port, AND that is the only USB 2.0 port active on the motherboard.I moved the USB cable connected to my UPS, keyboard and mouse to USB 3.0 and the issue went away for me after a few reboots and a cold startup. Samsung Bar Plus USB 3.0 & Asus B550-F Gaming Wifi II motherboard.
