JMB575 on m2 and how to power HDDs
Hi everyone!
I've recently begun playing around with unraid. My goal is to eventually use it as an automated back-up machine (think OneDrive, Google Photos replacement), an automated media downloader/server, and a VM host machine.
For this, I'm repurposing my old laptop: I'll remove it from its case, remove screen, etc and install it on a board.
The plan is to use a SATA to M.2 adapter (I'm eyeing this one with a JMB5xx chip) and connect several 3,5 and 2,5" disks to it.
I do have a couple of questions though!
1. Is this feasable?
2. How would you power the HDDs? I'd very much prefer to connect all disks pluged into the JMB5xx board to a single PSU or other device you'd recommend, for convenience and power savings.
At any rate, let me know your thoughts on this subject! Thank you beforehand
That's a PCIe to SATA controller, notebook must support NVMe in that slot, if it's SATA only it won't work.
Acording to MSI's website, it's a NVMe PCIe Gen3 / SATA port... Would that work?
Also, thanks so much for writing the Recommended controllers for Unraid thread, JorgeB: it's been of great help choosing the right adapter
Sorry, that one is JMB575, not 585 like I misread, 575 uses a SATA port multiplier, not recommend for Unraid, look for a similar looking adapter but based on a JMB585.
It should.
you can get any ATX PSU, a PSU like a Pico or similar would have better power consumption.
Got it, thanks! I've located this one that works, acording to reviews. What's the tech behind this chip? I mean, if the JMB575 is a "simple" sata multiplier, what's the JMB585?
It should.
Also, the laptop has an Intel wifi card. Is there a way to find out the characteristics of the port the cart is connected to?
I'm still early in the research of these PSUs, but if I understand correctly, I'd have to connect the Pico to the laptop's MB, right?
Thank you so much for taking the time!
Is there a reason to use the laptop?
I'd look to trade or sell rather than break up the laptop as it seems a reasonable model and has a discrete GPU.
Much easier to use standard hardware, psu, case etc.
For power efficiency you can get something like this ASROCK J5040 ITX which has 4 native SATA ports, could take a few more in a PCI-E card and Intel Quick Sync in case you decide you want a media server or plenty of inexpensive used hardware.
JMB585 is a 5 port SATA controller, the other one turns one SATA port into five, if the SATA port supports port multiplier, and like mentioned they are not recommended.
Mostly because it's what I have laying around.. though it is a good machine and has prob more than enough horse power for my projects, it is in a bad cosmetic state (broken case, wrecked charger cable, non working keyboard) and I won't be able to get much for it.
I might consider it down the line actually 🤔
So the jmb585 doesn't split the original SATA port's bandwidth 5 ways like a SATA multiplier?
Correct, it's an x2 PCIe 3.0 controller, IIRC about5 350MB/s for each device with all being used simultaneously.
Thanks JorgeB!
Sorry for the late reply.
In regards to the PicoPSU how would you go about powering the HDDs with it? I did some googling but have been unable to find an answer...
On second thought Pico PSU might not really be a good idea, since you'd need a lot of splitters and are not going to be using the ATX connector, just get a low power efficient ATX PSU.
