Help and advice with first setup
Hi all,
Ive just purchased a PC to use with Unraid.
My planned uses at the minute are
Plex
Home Assistant
Possibly a Windows VM for BlueIris
PC Specs
Z490 Motherboard
16Gb Ram
i9 10900k
120gb m.2
1tb sata SSD
I plan to add x3 4tb HDD and have a single parity drive
Im unsure how to use the SSDs though, as ones sata and ones M.2. What’s the best way to utilise the speed of the M.2 while using the capacity of the sata SSD?
Thanks
The m2 might be large enough as a 'fast' pool for the default shares.
https://wiki.unraid.net/Manual/Shares#Default_Shares
Then SSD could be cache pool for caching user shares
I’m probably best upgrading the m.2 aren’t I? Reading the link think I’ll need more as I’ll have a few containers running once I start playing. Would a 500gb be sufficient?
Also is 16gb enough ram?
Thanks
Edited by hemo87
You could keep some of the default shares on the SSD if there isn't enough space on the m.2
If you aren't caching several hundred GB per day the SSD will have some space leftover.
Don't cache initial data load if it is larger than cache.
Should be plenty.
If you don't plan to have a lot of VMs going at once should be plenty.
No... I would trade SSDs for RAM. Your storage needs (Plex, etc.) don't match your VM needs (Windows/BlueIris).
An SSD is $100/tb and a mechanical HD is $25/tb (close in most parts of the world).
In short... Screw the SSD/M2 crap and get RAM and mechanical drives (storage).
Just my humble opinion... shit...jmho... right?
MrGrey.
