March 9, 20233 yr Hey everyone, This might be the wrong section, I couldn't start a thread in the Plugin Support section as it was greyed out to me. I have the Auto Fan Plugin installed, but the service will ONLY enable if I enable the 1st PWM controller. I don't want Auto Fan to control this fan as it is the CPU fan, not the Array fan. The 3rd PWM controller is my Array fan. If I enable then disable the 1st PWM controller that will start the service, until I reboot...then I have to do it all again. Is there any way around this? Thanks in advance! Edited March 9, 20233 yr by Walkerfever
March 9, 20233 yr Just now, Walkerfever said: I couldn't start a thread in the Plugin Support section You are supposed to post in the existing plugin support thread, in this case:
March 9, 20233 yr Author 3 hours ago, JorgeB said: You are supposed to post in the existing plugin support thread, in this case: Gotcha, will do. Thanks for the help.
