March 13, 20233 yr Hi, I am having issue because sometime my unraid is freeze and cannot be accessible. I can only start back the server after cycle power. Hope someone can suggest what i can do to avoid issue from happen again. Herewith i attach the diagnostic file and some log that being captured via remote syslog server. Unraid Version: 6.11.5 Motherboard: Gigabyte Technology Co., Ltd. Z490 VISION G Processor: Intel® Core™ i9-10850K CPU @ 3.60GHz RAM: 64 GB Thank you. aiesb-svr-01-diagnostics-20230313-1116.zip aiesb-svr-syslog.log
March 13, 20233 yr Community Expert Syslog shows kvm related issues, does it crash without using VMs and/or vt-d disabled?
March 13, 20233 yr Author Hi @JorgeB, thanks for the reply. During crash, I have several VM and Docker running as well. Intel vt already enable on my motherboard. FYI, the diagnostic log is capture after power cycle the unit. The syslog is captured before the event happen. Edited March 13, 20233 yr by Muhamad Aidil Karim Add information
July 21, 20233 yr Author Solution Just to update on this issue. Flash newer bios on the motherboard seems to fixed this issue. Running 2 weeks now without freeze.
