July 29, 201115 yr I was about to move 620 GB of my cache drive. All was working well, then I looked at the Main page and the cache drive temp was reading 0 C, and I couldn't access it. I stopped and restarted the array, and the cache drive appeared unformatted. I rebooted the server and everything was okay again. I was able to write to the cache drive. So I initiated a manual move from Midnight Commander and it failed. Sure enough, the main page is showing a 0 C temp for the drive again. I'm going to reboot again and see what happens. Any suggestions other than, "Dude you should move stuff off the cache drive more frequently?"
July 29, 201115 yr "Dude you should move stuff off the cache drive more frequently?" (sorry, couldn't resist) The usual responses apply: provide your syslog (http://lime-technology.com/forum/index.php?topic=9880.0), run a smartctl -a /dev/sdX (replace X with the proper letter corresponding to this particular drive). Based on the info you've provided so far, it could be any of the following: - bad drive - bad cable - bad controller - bad driver/software - any combination of the above
