April 2, 20233 yr Hi there I was wondering how high water should work? I thought it would fill up all disks equally. I did activate it when all 3 disks had 2 TB free space but it seems to only fill up the first disk. I have set the split level to "automatically split any directory as required". From what I could find in the forum this should work, but it doesn't. Why is that?
April 2, 20233 yr Solution See the help text. In your current situation it'll only move to the next once disk3 has less than 1TB free.
April 2, 20233 yr Author 13 minutes ago, Kilrah said: See the help text. In your current situation it'll only move to the next once disk3 has less than 1TB free. Ah I see, I should have read that. Thank you very much.
April 2, 20233 yr 26 minutes ago, Akuno said: Ah I see, I should have read that. Thank you very much. There is also a good example in the the online documentation accessible via the ‘Manual’ link at the bottom of the GUI or the DOCS link at the top of each forum page.
