Please Review my first UnRAID Server Parts List
$99.00 - MOTHERBOARD : Asus P5B-VM DO http://www.lagoom.com/ASUS_Motherboard_P5B-VM_DO_LGA775/P5B-VM_DO/partinfo-id-569698.html
$43.99 – CPU : Celeron 420 1.6GHz http://www.newegg.com/Product/Product.aspx?Item=N82E16819116040
$34.00 (After MIR) – RAM : CORSAIR XMS2 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) http://www.newegg.com/Product/Product.aspx?Item=N82E16820145590
$149.99 – CASE - COOLER MASTER CM Stacker STC-T01-UWK http://www.newegg.com/product/product.aspx?item=N82E16811119039
$49.00 (After MIR) – PSU - Thermaltake Purepower W0129RU ATX12V 600 W Power Supply http://www.newegg.com/Product/Product.aspx?Item=N82E16817153042
$35.98 ($17.99.ea x2) – 4 in 3 Cage - COOLER MASTER STB-3T4-E1-GP 4 in 3 Device Module W/ FAN – Retail http://www.newegg.com/product/product.aspx?item=N82E16811999169
$411.93 + $69 unRAID Server Plus (6 Drive)
Drives (What I have available already)
Seagate 7200.10 750GB (x2)
Seagate 7200.8 400 GB (x3)
Seagate 7200.9 500 GB (x1)
*Edit, I might have a 7200.10 PATA that could also use in place of the one of the 400 gB if that's possible (I think the MB only has 1 PATA)
Total of 2.45 TB Usable – with 750GB Parity <correct???>
(Future)
$249.98 – ($124.99 /ea x2) – 5 in 3 Cages - AMS DS-3151SSBK http://www.newegg.com/Product/Product.aspx?Item=N82E16817332011
You are correct.  You will have 2.45 TB of storage space for your data.
You are positioned well for sales on 750 Gig drives for expansion.
I'm not really sure about the Case still... while I'm sure this case is NICE, it's more 1/3 of the price of the whole setup and I'm not sure I'm going to need/want a huge 16 Drive setup or anything...
$89.99 (After MIR) – CASE : Antec P182 http://www.newegg.com/Product/Product.aspx?Item=N82E16811129025
I'm thinking about that case now. I have a P180 for one of my other PC's, and it's one of the nicest cases I've ever worked on (as long as the PSU cables are long enough since the PSU sits on the bottom away from the MB.
If I could still use a 5in3 or 4in3 in the top external 5.25", I could get either 6 or 7 internally with what I believe is adequate cooling, for a total of 10-12 drives total depending on how I had it setup. I think this will be fine (especially since I'm only starting with 6 (I think).
Any thoughts on unRAID case options?
SW2
I've got two unRAID - both in CM towers. One has two P/S in it and a nearly full set of drives, the other uses Supermicro 5in3 cages and a single P/S. Both cases are EASY to work with, don't have tons of sharp edges, and cool well. When it came time to buy a second case for my second box I didn't think twice, I bought a CM case much like the first only without the second P/S mount inside. They aren't dirt cheap but they also do not fall apart or cut me when I work inside them. I bought them for the long haul not for something I'd only be using a year.
One thing to consider is that the CoolerMaster Stacker is meant to be a case that holds a huge pile of drives.  Not so much the P182, which I think is geared more towards the gamer crowd.  This means that there will be a lot of airflow dedicated to cooling the CPU and PCI-e slots.  But in your case, the CPU will barely be drawing anything, and you won't be having three power-sucking video cards in your slots.  Instead, all of your heat will be coming from the front, and your hard disks will be putting out a lot more heat than any optical drive.
SirWired
I have the P180, basically the same as the P182.  No, it really isn't a case if all you want is a big stack of drives.  Too many compartments, for example.
I like it, but not as an unraid case.  Since I need to build a new desktop system anyway, I will repurpose the P180 to my new desktop and will buy a true server case (big, empty space is all I need).
Bill
Well, I pulled the trigger on some stuff tonight...
Case COOLER MASTER CM Stacker STC-T01-UWK http://www.newegg.com/product/product.aspx?item=N82E16811119039
Motherboard Asus P5B-VM DO http://www.lagoom.com/ASUS_Motherboard_P5B-VM_DO_LGA775/P5B-VM_DO/partinfo-id-569698.html
Power Supply CORSAIR CMPSU-550VX ATX12V V2.2 550W Power Supply http://www.newegg.com/Product/Product.aspx?Item=N82E16817139004
HD BackPlane (x2) Icy Dock 5 In 3 SATA I/II Module http://www.newegg.com/Product/Product.aspx?Item=N82E16817994028&Tpk=MB455SPF-B
CPU Intel Celeron 440 Conroe-L 2.0GHz LGA 775 35W Single-Core Processor Model BX80557440 - Retail http://www.newegg.com/Product/Product.aspx?Item=N82E16819116038
Memory A-DATA 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory http://www.newegg.com/Product/Product.aspx?Item=N82E16820211066
SATA Card SUPERMICRO AOC-SAT2-MV8 64-bit PCI-X133MHz SATA Controller Card http://www.newegg.com/product/product.aspx?item=N82E16815121009
I didn't buy everything from Newegg or Lagoom, but used those links for reference.
I went ahead and got the extra SATA  Card beucase I think I have access to a pile of 300-400 GB SATA's that I might bump my initial setup to 10 Drives, but will have to see.  I will be ready for the extra drives with this setup (at least to 10, physically will just need a 3rd Backplane).
That SuperMicro card is a PCI-X card.  The motherboard you link to does not have any PCI-X slots.  It's not going to work.
Really? ... it was also posted somewhere (either here or AVSforum) that this card also works on standard PCI Slot as well... will need to find the Post...
http://lime-technology.com/forum/index.php?topic=976.0
You're right and I never even stopped to think for a second that you'd put it in a PCI slot.  I've been messing with these PowerEdges that don't have PCI slots for so long that I forget about them.  Forgive my silliness  :)
The Icy Docks are very nice. I put 2 of them in my case
NICE, I hadn't see a lot of talk about that specifc branded backplane on here or AVSForum and was hoping they would be decent!
Thanks
Wade
Yeah. they are well designed and very strong. worked perfect in my Lian Case. They should work really well in that Stacker case you've ordered. I recommend tagging each end of your sata cables (port #) before you plug them all in. Its easier to trace wires later.
Thanks for the tip... I just printed a bunch of labels for the SATA Cables as well as for for the front of the trays to try to keep everything neat and organized... I'm just impatiently waiting for all my stuff to arrive... MB Showed up yesterday, and I have the drives (most of em) and everything else is intransit.
