April 19, 20233 yr server seems to start up fine with no obvious issues, apps in docker fire right up, can use them without issues, then randomly could be 5 min, 5 hours, 5 days, sometimes several weeks but it will diappear from network entirely and only way to get it back online is hard shutdown and start back up. ive tried everything i can think of to resolve the issue, current setup only has 8gb ram which ill be upgrading soon but even in hardware i had it running on once before with dual xeon cpu's and 128gb ram it had the same exact problems. gonna go restart it now and pull the logs as i know its hard for anyone to offer any advice withhout them
April 19, 20233 yr Community Expert Enable the syslog server and post that after a crash together with the diagnostics.
April 19, 20233 yr Author diagnostics attached here, any help or suggestions would be greatly appreciated media1-diagnostics-20230419-1107.zip
April 19, 20233 yr Community Expert 1 minute ago, ibelouis said: i think i have syslog server enabled already If you do you still need to post it, it doesn't come with the diags.
April 19, 20233 yr Community Expert That's the regular syslog, the one that starts over after every reboot, not the persistent syslog from the syslog server.
April 19, 20233 yr Author thats turned on as well but nothing in the folder its said to be saved in, enabled mirror to flash drive. maybe will find it there after next crash?
April 19, 20233 yr Community Expert 11 minutes ago, ibelouis said: enabled mirror to flash drive. maybe will find it there after next crash? Try that, it will be in the /logs folder.
April 19, 20233 yr Author log posted moment ago was from today according to filename, about 30 min before i posted it
April 19, 20233 yr Community Expert 31 minutes ago, JorgeB said: That's the regular syslog, the one that starts over after every reboot, not the persistent syslog
April 20, 20233 yr Author this is def a first, array is started up, plex streaming, vm i use time to time booted too
April 20, 20233 yr Author oh and every page tells me array not started but has all normal stuff if array is running
April 20, 20233 yr Community Expert 7 hours ago, ibelouis said: syslog hopefully this is it? What time was the last crash? 7 hours ago, ibelouis said: oh and every page tells me array not started but has all normal stuff if array is running You should reboot, also make sure you are not using Firefox
April 20, 20233 yr Author i use firefox on all my devices after i found out google was selling my data from all their apps
April 21, 20233 yr Community Expert There are known issues with Firefox and Unraid, if it's asks to resend data click cancel or GUI will get stale.
May 11, 20233 yr Author i always hit cancel to resend data. even if i dont open gui on browser, it still crashes after random amount of time
May 11, 20233 yr Community Expert Crashing won't be related to Firefox, this is: On 4/20/2023 at 1:09 AM, ibelouis said: oh and every page tells me array not started but has all normal stuff if array is running
