April 20, 20233 yr I have a Pihole Container running which is not reachable when I Copy Data from the Array. The Appdata Folder has its own NVME SSD (Virtual_stuff) which is not the Array Cache. Other Containers run smoothly while data transfer. CPU is I5-13500 with 32 GB RAM. (Not much running at the moment, system is chilling) The Pihole has its own br0 Network (Only Container/VM with an dedicated Virtual Host Adapter) The SSD where Appdata is stored shows me 2.27TB while the NVME SSD has only 1TB and there is no other Cache for it: Where am I here wrong here with the config? Edited April 20, 20233 yr by julianc
April 20, 20233 yr Author Solution I found out, that the mover tool dosent copy files after changing the destination automatically (I changed Hardware): Can this be forced to reorganize the Data to its destination which was set?
