August 12, 201115 yr Hey guys, My power went out earlier today and my Unraid server doesn't seem to be coming back up correctly. I have a 2 TB drive that's on a IDE -> SATA converter and that drive just shows in the main display as "Mounting" with a green light. Enclosed is my syslog, let me know what other info you might need. Oh and I'm running version 4.7 Pro. Thanks, Doug syslog-2011-08-12.txt
August 13, 201115 yr I've seen a similar thing for my server. If you look at the webpage is that drive being written to? If it is, wait it out and eventually (at least for me) it will mount and start a parity check. dave
August 15, 201114 yr Author I powered the server down for a while thinking a full reset may help. Based on your post I started it back up and let it go and you're right it eventually came up and started the parity check. Thanks for the tip! Doug
