May 20, 20233 yr I am replacing my parity with a larger drive after a different drive failed, and am putting the old parity into the array. I am currently around 78% into the process and at some point during the night, fix common problems gave the "error" disk6 (WDC_DRIVE SERIAL HERE) is disabled. Is this normal, or is there a real error? In the fix common problem app, it says "Begin Investigation Here" with a button that just goes to the unraid MAIN page. It appears the process is still moving forward, normal or not?
May 20, 20233 yr Solution Probably because until the process completes, there may still be references etc to the old drive.
May 20, 20233 yr Author This seems to be correct, so thank you for putting any of my concerns to rest. Thanks again.
