July 11, 20233 yr Been running Unraid for about a week. Old Ryzen 7 1700, GTX 1080 gaming pc. No known hardware issues. Since day 1, the array has gone down randomly about once per day when I'm not watching. Sometime just the array is down, sometimes the entire OS crashes. I haven't found a hint in the unraid logs or Find Common Problems. All I have is this one photo of a kernel panic log I found on my monitor when I got home. Fix Common Problems shows nothing of consequence. Memtest86 passed with no errors. Syslog (mirrored to flash) only shows healthy bootup logs with long gaps in between - nothing about a crash. I really don't expect to find a hardware issue. This machine has tanked everything I've thrown at it - Many OSes, servers, VMs, games, media playback. It had no issue until I installed Unraid. I'm not sure what to try next. Any suggestions? I have lots of docker containers actively running, but the crashes seem to happen regardless of which ones are on. Also, my cache seems to run a bit hot, but idk how significant that is. Please let me know your thoughts.
July 11, 20233 yr Author 21 minutes ago, trurl said: This looks to be the solution. I disabled Global C States and AMD Cool'n'Quiet. I'm betting that's my answer. If not, I'll slow the RAM down. Gonna mark this resolved. Thanks a bunch. Edited July 11, 20233 yr by ahreed304 forgot a sentence
