July 16, 20233 yr Author everytime my move runs it fills the cache drive and is unusable now. everting that was working stops because the cache drive is full. Which of course starts a whole new series of problems.
July 16, 20233 yr Community Expert Note that any share that has Use Cache=Prefer will try to move data onto the pool. I suspect that you do not want this for the ‘data’ share? The other ones set to Prefer are normally kept on the cache for optimal performance. You should also set a sensible Minimum Free Space value for the cache to prevent it filling up completely if everything configured to go there will not fit.
July 16, 20233 yr Author the server is not working again. docker wont start and my vms are not loading. unbalance wont move files (it starts and shows progress but nothing is shown as moved in the main tab) i changed cache settings on the shares. my log is completely full. How do i fix this and get it back to operational. Soo frustrated now,
July 17, 20233 yr Community Expert 18 hours ago, BigRed8150 said: what should they be set to ? cache=yes
July 17, 20233 yr Community Expert 20 hours ago, BigRed8150 said: looking at my settings, what should they be set to ? I would think the 'data' share should be Use Cache=Yes, while the others look OK. The help built into the GUI explains the options and how they interact with mover.
