Fix Common Problems: Disk has read errors
Hi guys,
i got the topics message for both of my HDDs and i am not sure how to proceed from here (replacement of both drives, a single one, ignore?).
The diagnostic zip and both extended smart tests are attached. Also i did a manual parity check which didnt show any errors.
If i hover over the Smart status on the Dashboard for both HDDs, both have the Error status, i see Reallocated Sector Cound: 207 for the parity disk and 56 for disk1.
Any advice would be appreciated.
Kind regards,
Maenshae
unraid-diagnostics-20230715-1323.zip unraid-smart-20230715-1322-parity.zip unraid-smart-20230715-1322-disk1.zip
Solved by JorgeB
Both are logged as disk errors, run an extended SMART test on both, but even if it passes, if there are more errors in the near future I would replace them.
