July 16, 20233 yr I have a small Unraid server that I am changing out the Parity disk. My current set up: 4TB Parity disk on sdc 4TB Data disk on sdd 16GB flash drive 256GB SSD Cache drive New 8TB Parity is being precleared on sde I am replacing the Parity disk with a 8TB disk currently on sde being precleared. My concern is once preclear is complete I will make the new disk Parity 2 and let the old Parity disk update the new parity disk with the intention of once that is complete remove the old Parity disk and the new 8TB drive the only Parity drive (Parity 1). Once the 8TB is updated to Parity 1 I have to take it off the current power location on the power cable and plug it into the old parity drive location on the power cable and plug the old parity cable (sdc) into the new 8TB drive. This is in order to get the drive to fit in the box and the cable to reach the drives to close the case up. Is this a problem having the new 8TB being updated on sde and then changing to sdc once the old parity drive is removed? Thanks Ozzborn tower-diagnostics-20230716-1455.zip
July 16, 20233 yr Community Expert Parity2 is not interchangeable with parity1 as they use different algorithms to calculate their content. if you want the 8TB drive to end up as parity1 then you should do that from the outset. Just keep the current parity1 drive intact until you have completed building parity2 on the 8TB drive just in case problems are encountered. BTW: the /dev/sdX identifiers are irrelevant to Unraid - it tracks disks by their serial number, not by where they are connected.
July 16, 20233 yr Author 3 hours ago, itimpi said: Parity2 is not interchangeable with parity1 as they use different algorithms to calculate their content. if you want the 8TB drive to end up as parity1 then you should do that from the outset. Just keep the current parity1 drive intact until you have completed building parity2 on the 8TB drive just in case problems are encountered. BTW: the /dev/sdX identifiers are irrelevant to Unraid - it tracks disks by their serial number, not by where they are connected. Do you mean remove the old Parity disk and set it aside ..... and let the new Parity drive be rebuilt from the data disk?
July 17, 20233 yr Community Expert Solution 8 hours ago, ozzborn said: Do you mean remove the old Parity disk and set it aside ..... and let the new Parity drive be rebuilt from the data disk? Yes That way if by any chance there a dive fails when building the new parity1 disk you have the old one available for recovery purposes.
