July 25, 20233 yr Hi, my server powered itself off in the middle of the night, no one near it. Is elogind-daemon part of the standard unRAID build please ? Jul 25 02:32:54 Tower emhttpd spinning down /dev/sdd Jul 25 03:01:11 Tower root /mnt/cache: 83.7 GiB (89874059264 bytes) trimmed Jul 25 03:04:06 Tower elogind-daemon Power key pressed. Jul 25 03:04:06 Tower elogind-daemon Powering Off... Jul 25 03:04:06 Tower elogind-daemon System is powering down.. Jul 25 03:04:06 Tower shutdown shutting down for system halt Jul 25 03:04:06 Tower init Switching to runlevel: 0 Jul 25 03:04:06 Tower flash_backup stop watching for file changes
July 31, 20233 yr Community Expert Try this: https://forums.unraid.net/topic/125714-unraid-forcing-graceful-shutdown-on-hpe-proliant-server/?do=findComment&comment=1147121
July 31, 20233 yr Author Yes I saw that thread and the comment about is this something you installed. Hence my query on this thread, as I have not knowingly installed elogind...
July 16, 20242 yr Just thought I would post some more information on this error. I have had the same problem with a system always powering down ~3-4min after being turned on. Jul 15 21:08:33 Tower elogind-daemon[1185]: Power key pressed. Jul 15 21:08:33 Tower elogind-daemon[1185]: Powering Off... Jul 15 21:08:33 Tower elogind-daemon[1185]: System is powering down.. Jul 15 21:08:33 Tower elogind-daemon[1185]: Suspend key pressed. Jul 15 21:08:33 Tower shutdown[7531]: shutting down for system halt This is on a brand new vanilla USB that had just been created by the USB Creator for both 6.12 and 7.0-beta2. There was no issue in memtest or when booting Windows. After a bit of digging it seems to be due to USB. I had a USB keyboard and LCD monitor (USB powered) connected. I'm not sure if they were pulling too much power or the keyboard was sending a power off command over USB. Anyway, just unplugging the devices fixed the issue. Edit: Seems to only happen if the keyboard is plugged into USB on system boot. Hmmm... Edited July 16, 20242 yr by cat2devnull
