July 26, 20233 yr I switched from an onboard 10g aquantia nic that was failing to a Mellanox ConnectX-3 card yesterday. The Aqua nice was ethernet to SFP+, the ConnectX card is SFP+ to SFP+. The ConnectX card is in ethernet mode and fully updated. It works, unraid sees it, and it can connect to my other servers on the network. The issue is myunraid wont connect, Wiregaurd wont connect, and I deleted the SSL cert from the management access section and tried to reprovision it, but it fails to reprovision. I have all the same settings as before and obviously this all worked prior to the switch. I made sure the correct ports were forwarded in my Ubiquiti network as well. It all works on my other server on the network and my 3rd unraid machine offsite. Not sure what to do at this point, I have fiddled quite a bit with it so far. I am on Unraid 6.12.3 and attached diags. nas1-diagnostics-20230726-1119.zip
August 11, 20233 yr Author Solution It was a problem with the routing table. Default gateway was pointing to BR1 and should ahve been BR0. Couldnt edit the routing table so I deleted the network.cfg, rebooted and was golden!
