July 28, 20233 yr I've put a Gigabyte MZ32-AR0 in a Supermicro 826 and am having some issue detecting the two PSUs PWS-920P-SQ I also can't get the lights on the front of the chassis to work https://download.gigabyte.com/FileList/Manual/server_manual_MZ32-AR0_e_v10.pdf I have the following pins plugged in using a Supermicro Front Control Split Cable CBL-0084L Pin 1 3 5 - PW LED Pin 7 9 - HDD LED Pin 11 13 - PW SW Pin 15 17 - RESET SW Not plugged in: NIC LED POWER FAIL O H LED NIC LED Pin layout taken from above manual: Is it possible to get these two issues above working in a Supermicro chassis?
