August 1, 20233 yr Hi, Woke up to some strange issues with my Unraid box but have now tracked it down to a power cut which happened overnight and the box booted back up ok but the management ports (http & https) had reset back to the default from my set ports and also the time zone had reset so the clock was wrong. I'm still looking for anything else which might have reset with the power cut but everything else seems ok so far, dockers, VMs, data, plugins, etc. Has this happened to anyone else? Annoyingly I thought the box had locked up so powered it off a couple of times before thinking to test the standard ports (it's a headless unit so is a faff to attach a monitor and it has locked up in the past). Thanks for reading, David
August 1, 20233 yr Author ok, thanks Jorge - presumably I can't do that live and need to put the flash drive in to another machine to run it?
