August 3, 20233 yr Hi, I needed to reboot my unraid today due to some strange behaviour. The mainscreen did not show any of the info in the upper sections - logo kept circling - only array operations were visible. Updating docker and plugins did not show progress or any button - reloading the page after some time showed the dockers being updated. Starting a VM was not possible with the error message that the domain was already running/in use. Uptime was about 14 days, as far as I recon. I decided to reboot and all went back to normal. I then received the notification from the fix common problems plugin about machine check events being detected. All is running fine at the moment - but uncertain about the background. Appreciate and help to identify if I shoudl be worried and prepare replacement of some component or if I can ignore the error. Thanks! Thomas skynetcentral-diagnostics-20230803-1633.zip
