August 25, 20233 yr Hey guys, I'm having an issue booting up Unraid after installing some new hardware. It boots up, but very slowly and gives the "eth0" does not exist error. I've checked the network cable on another computer and it works fine, so that means its either a software or (hopefully not motherboard) hardware problem. I'm fairly new to Unraid and linux in general so I'm not sure where to even start to troubleshoot this. I've attached my syslog. Any help is appreciated thank you! syslog.txt
August 25, 20233 yr Author Solution I figured it out. I used an ethernet to usb adapter and it picked up the connection right away. RIP my motherboard gotta return it. Thanks for the responses I appreciate it.
