August 26, 20232 yr I have a windows 11 vm that was working fine. Not sure when, but now whenever I try to play a game, all my screens go blank. I search this problem. I updated my bios, changed the power settings (which worked for 10minutes). not sure what to try next. here is my vm logs and diagnstics 2023-08-26 00:50:54.938+0000: Starting external device: TPM Emulator /usr/bin/swtpm socket --ctrl 'type=unixio,path=/run/libvirt/qemu/swtpm/1-Windows 11-swtpm.sock,mode=0600' --tpmstate dir=/var/lib/libvirt/swtpm/20e51a8f-6a13-30f2-7917-43702d4600ae/tpm2,mode=0600 --log 'file=/var/log/swtpm/libvirt/qemu/Windows 11-swtpm.log' --terminate --tpm2 2023-08-26 00:50:54.957+0000: starting up libvirt version: 8.7.0, qemu version: 7.1.0, kernel: 5.19.17-Unraid, hostname: impact LC_ALL=C \ PATH=/bin:/sbin:/usr/bin:/usr/sbin \ HOME='/var/lib/libvirt/qemu/domain-1-Windows 11' \ XDG_DATA_HOME='/var/lib/libvirt/qemu/domain-1-Windows 11/.local/share' \ XDG_CACHE_HOME='/var/lib/libvirt/qemu/domain-1-Windows 11/.cache' \ XDG_CONFIG_HOME='/var/lib/libvirt/qemu/domain-1-Windows 11/.config' \ /usr/local/sbin/qemu \ -name 'guest=Windows 11,debug-threads=on' \ -S \ -object '{"qom-type":"secret","id":"masterKey0","format":"raw","file":"/var/lib/libvirt/qemu/domain-1-Windows 11/master-key.aes"}' \ -blockdev '{"driver":"file","filename":"/usr/share/qemu/ovmf-x64/OVMF_CODE-pure-efi-tpm.fd","node-name":"libvirt-pflash0-storage","auto-read-only":true,"discard":"unmap"}' \ -blockdev '{"node-name":"libvirt-pflash0-format","read-only":true,"driver":"raw","file":"libvirt-pflash0-storage"}' \ -blockdev '{"driver":"file","filename":"/etc/libvirt/qemu/nvram/20e51a8f-6a13-30f2-7917-43702d4600ae_VARS-pure-efi-tpm.fd","node-name":"libvirt-pflash1-storage","auto-read-only":true,"discard":"unmap"}' \ -blockdev '{"node-name":"libvirt-pflash1-format","read-only":false,"driver":"raw","file":"libvirt-pflash1-storage"}' \ -machine pc-i440fx-7.1,usb=off,dump-guest-core=off,mem-merge=off,memory-backend=pc.ram,pflash0=libvirt-pflash0-format,pflash1=libvirt-pflash1-format \ -accel kvm \ -cpu host,migratable=on,topoext=on,hv-time=on,hv-relaxed=on,hv-vapic=on,hv-spinlocks=0x1fff,hv-vendor-id=none,host-cache-info=on,l3-cache=off \ -m 24576 \ -object '{"qom-type":"memory-backend-ram","id":"pc.ram","size":25769803776}' \ -overcommit mem-lock=off \ -smp 16,sockets=1,dies=1,cores=8,threads=2 \ -uuid 20e51a8f-6a13-30f2-7917-43702d4600ae \ -display none \ -no-user-config \ -nodefaults \ -chardev socket,id=charmonitor,fd=36,server=on,wait=off \ -mon chardev=charmonitor,id=monitor,mode=control \ -rtc base=localtime \ -no-hpet \ -no-shutdown \ -boot strict=on \ -device '{"driver":"ich9-usb-ehci1","id":"usb","bus":"pci.0","addr":"0x7.0x7"}' \ -device '{"driver":"ich9-usb-uhci1","masterbus":"usb.0","firstport":0,"bus":"pci.0","multifunction":true,"addr":"0x7"}' \ -device '{"driver":"ich9-usb-uhci2","masterbus":"usb.0","firstport":2,"bus":"pci.0","addr":"0x7.0x1"}' \ -device '{"driver":"ich9-usb-uhci3","masterbus":"usb.0","firstport":4,"bus":"pci.0","addr":"0x7.0x2"}' \ -device '{"driver":"virtio-serial-pci","id":"virtio-serial0","bus":"pci.0","addr":"0x3"}' \ -device '{"driver":"usb-hub","id":"hub0","bus":"usb.0","port":"1"}' \ -blockdev '{"driver":"file","filename":"/mnt/user/isos/virtio-win-0.1.229-1.iso","node-name":"libvirt-1-storage","auto-read-only":true,"discard":"unmap"}' \ -blockdev '{"node-name":"libvirt-1-format","read-only":true,"driver":"raw","file":"libvirt-1-storage"}' \ -device '{"driver":"ide-cd","bus":"ide.0","unit":1,"drive":"libvirt-1-format","id":"ide0-0-1"}' \ -netdev tap,fd=37,id=hostnet0 \ -device '{"driver":"virtio-net","netdev":"hostnet0","id":"net0","mac":"52:54:00:08:7d:1a","bus":"pci.0","addr":"0x2"}' \ -chardev pty,id=charserial0 \ -device '{"driver":"isa-serial","chardev":"charserial0","id":"serial0","index":0}' \ -chardev socket,id=charchannel0,fd=35,server=on,wait=off \ -device '{"driver":"virtserialport","bus":"virtio-serial0.0","nr":1,"chardev":"charchannel0","id":"channel0","name":"org.qemu.guest_agent.0"}' \ -chardev 'socket,id=chrtpm,path=/run/libvirt/qemu/swtpm/1-Windows 11-swtpm.sock' \ -tpmdev emulator,id=tpm-tpm0,chardev=chrtpm \ -device '{"driver":"tpm-tis","tpmdev":"tpm-tpm0","id":"tpm0"}' \ -device '{"driver":"usb-tablet","id":"input0","bus":"usb.0","port":"1.7"}' \ -audiodev '{"id":"audio1","driver":"none"}' \ -device '{"driver":"vfio-pci","host":"0000:0d:00.0","id":"hostdev0","bus":"pci.0","multifunction":true,"addr":"0x4"}' \ -device '{"driver":"vfio-pci","host":"0000:0d:00.1","id":"hostdev1","bus":"pci.0","addr":"0x4.0x1"}' \ -device '{"driver":"vfio-pci","host":"0000:01:00.0","id":"hostdev2","bus":"pci.0","addr":"0x6"}' \ -device '{"driver":"vfio-pci","host":"0000:05:00.0","id":"hostdev3","bus":"pci.0","addr":"0x8"}' \ -device '{"driver":"vfio-pci","host":"0000:06:00.0","id":"hostdev4","bus":"pci.0","addr":"0x9"}' \ -device '{"driver":"vfio-pci","host":"0000:08:00.0","id":"hostdev5","bus":"pci.0","addr":"0xa"}' \ -device '{"driver":"vfio-pci","host":"0000:09:00.0","id":"hostdev6","bus":"pci.0","addr":"0xb"}' \ -device '{"driver":"vfio-pci","host":"0000:09:00.1","id":"hostdev7","bus":"pci.0","addr":"0xc"}' \ -device '{"driver":"vfio-pci","host":"0000:09:00.3","id":"hostdev8","bus":"pci.0","addr":"0xd"}' \ -device '{"driver":"vfio-pci","host":"0000:0f:00.0","id":"hostdev9","bus":"pci.0","addr":"0xe"}' \ -device '{"driver":"vfio-pci","host":"0000:0f:00.1","id":"hostdev10","bus":"pci.0","addr":"0xf"}' \ -device '{"driver":"usb-host","hostdevice":"/dev/bus/usb/005/002","id":"hostdev11","bus":"usb.0","port":"2"}' \ -device '{"driver":"usb-host","hostdevice":"/dev/bus/usb/005/003","id":"hostdev12","bus":"usb.0","port":"3"}' \ -sandbox on,obsolete=deny,elevateprivileges=deny,spawn=deny,resourcecontrol=deny \ -msg timestamp=on char device redirected to /dev/pts/0 (label charserial0) 2023-08-26T00:54:29.224977Z qemu-system-x86_64: vfio: Unable to power on device, stuck in D3 2023-08-26T00:54:29.225958Z qemu-system-x86_64: vfio: Unable to power on device, stuck in D3 2023-08-26T00:54:31.158951Z qemu-system-x86_64: vfio: Unable to power on device, stuck in D3 2023-08-26T00:55:42.439357Z qemu-system-x86_64: vfio: Unable to power on device, stuck in D3 2023-08-26T00:55:42.439486Z qemu-system-x86_64: vfio: Unable to power on device, stuck in D3 impact-diagnostics-20230825-2143.zip
August 29, 20232 yr Author problem solved. The only thing I did was update my Unraid. removed my 1030 from slot one, and moved my 3090 back to slot one deleted my old VM and rebuilt it over. everything is working fine so far.
