August 26, 20232 yr Hey guys, So i got an Unraid Server with 4 disks, I noticed that it takes me to transfer 6gb for 10 minutes with 10mbs speed. I tried replacing the cable, its connected to the router, removed the network config file and still no change.
August 26, 20232 yr Community Expert The NIC you are using only reports 10 and 100Mbis supported: Supported link modes: 10baseT/Half 10baseT/Full 100baseT/Half 100baseT/Full Do you have an addon NIC you can use? Ideally from Intel.
