August 27, 20233 yr Hi, It would be great to see how much power the Unraid server has consumed monthly/weekly/daily, the information can probably quiet easily be extracted from the APC webintegration. The information could then be parsed to the dashboard.
November 26, 20232 yr On 8/27/2023 at 8:00 AM, Fifthy said: Hi, It would be great to see how much power the Unraid server has consumed monthly/weekly/daily, the information can probably quiet easily be extracted from the APC webintegration. The information could then be parsed to the dashboard. Can you provide the output of /sbin/apcaccess
November 26, 20232 yr Author 5 hours ago, SimonF said: Can you provide the output of /sbin/apcaccess Hi Simon, Yes i can but when i open it with cat or nano it's basicly just jibberish with some log info, do i need to use another application to get it rightly formated?
November 26, 20232 yr 5 minutes ago, Fifthy said: /sbin/apcaccess ^ This is the command to run in the terminal rather than cat or nano
November 26, 20232 yr Author 6 minutes ago, SimonF said: ^ This is the command to run in the terminal rather than cat or nano Ofcourse, this is the output: Quote APC : 001,044,1034 DATE : 2023-11-26 14:10:57 +0100 HOSTNAME : Server VERSION : 3.14.14 (31 May 2016) slackware UPSNAME : APCUPS CABLE : Ethernet Link DRIVER : SNMP UPS Driver UPSMODE : Stand Alone STARTTIME: 2023-11-26 04:40:03 +0100 MODEL : Smart-UPS 1500 STATUS : ONLINE LINEV : 233.0 Volts LOADPCT : 8.0 Percent BCHARGE : 100.0 Percent TIMELEFT : 129.0 Minutes MBATTCHG : 10 Percent MINTIMEL : 10 Minutes MAXTIME : 0 Seconds MAXLINEV : 234.0 Volts MINLINEV : 233.0 Volts OUTPUTV : 233.0 Volts SENSE : High DWAKE : 1000 Seconds DSHUTD : 120 Seconds DLOWBATT : 5 Minutes LOTRANS : 207.0 Volts HITRANS : 253.0 Volts ITEMP : 31.0 C ALARMDEL : No alarm BATTV : 27.0 Volts LINEFREQ : 49.0 Hz LASTXFER : Automatic or explicit self test NUMXFERS : 0 TONBATT : 0 Seconds CUMONBATT: 0 Seconds XOFFBATT : N/A SELFTEST : OK STESTI : OFF STATFLAG : 0x05000008 MANDATE : 08/08/2015 SERIALNO : 3S1532X01316 BATTDATE : 03/15/2020 NOMOUTV : 230 Volts FIRMWARE : UPS 09.3 (ID18) END APC : 2023-11-26 14:11:49 +0100
November 26, 20232 yr 32 minutes ago, Fifthy said: Ofcourse, this is the output: Would you be able to show output from the web interface?
November 26, 20232 yr Author 3 hours ago, SimonF said: Would you be able to show output from the web interface? Here's a screenshot, do you need anything else from the webif?
November 26, 20232 yr 14 minutes ago, Fifthy said: Here's a screenshot, do you need anything else from the webif? Sorry I meant the web interface from the APC UPS, I dont have one so does that show history or not?
November 26, 20232 yr Author Here are some screenshots that I consider to be interesting for this: As you can see, there is data in the UPS that either directly tells you how much the consumption is, or there are parameters from which you can calculate it yourself (amps, voltage). How to extract them is beyond me.
