August 30, 20233 yr I purchased the Basic license using the summer promo code with the intent of then purchasing the Basic > Pro upgrade also using the promo. However when I try to activate the Basic license it says it can't because I have too many attached disks (7) and doesn't give me any direct patch to purchase an upgrade. Do I have any options to upgrade the Basic license to the Pro license using the promo here? Right now it seem like I have to purchase either the Plus or Pro at full price and eat what I already spent on the Basic.
August 30, 20233 yr Author Same result. Even with the array stopped, it still recognizes that my GUID is associated with 7 attached devices.
August 30, 20233 yr If you have any unassigned devices, remove them, activate the Basic license and upgrade. Otherwise, contact support https://unraid.net/contact
August 30, 20233 yr Solution You can also do this: https://forums.unraid.net/topic/143234-basic-too-many-attached-devices-to-activate/?do=findComment&comment=1292305
August 30, 20233 yr Author Thanks, the 7 attached disks are all assigned array/pool devices. I could probably remove one of them temporarily, but I'd rather not if it can be avoided. I've already submitted the support contact form, I will wait and see what they say. Thanks again.
August 30, 20233 yr Author 3 hours ago, JorgeB said: You can also do this: https://forums.unraid.net/topic/143234-basic-too-many-attached-devices-to-activate/?do=findComment&comment=1292305 forgive the question as I'm not familiar with the command: Will this have any destructive impact on the contents of the disk or its relationship to the array? Or after rebooting will whatever disk I chose return to the state it was in when the array was stopped? Like if I choose my parity disk, am I going to end up having to rebuild the parity? Edited August 30, 20233 yr by alexdrinan
August 31, 20233 yr 9 hours ago, alexdrinan said: Will this have any destructive impact on the contents of the disk or its relationship to the array? No, it just takes the disk offline, after a reboot all will be back as before.
August 31, 20233 yr Author 14 hours ago, JorgeB said: No, it just takes the disk offline, after a reboot all will be back as before. That did the trick, licenses are all squared away and all disks back in operation as expected. Thank you!
