September 9, 20233 yr I recently moved my unraid system to a new bigger case. The only other part that changed is the power supply. I needed longer cables so I pulled an old one out. It does have a lower rating of 400w. I think the one I was using had 650w. Since that change randomly my system will stop responding. I won't be able to access any of the dockers, VMs, gui or files. I go to the computer and it is still on. If I reset it everything comes back. I have looked in the syslog and nothing at all stands out around the crash. I think it is the power supply though I am surprised 400w isn't enough. Before I get a new one I wanted to see if there was anything else I should check. I've attached the syslog and diagnostics. There are multiple crashes in this syslog but there is one right before the bottom between 18:35 and 19:48 on the 8th. Thanks for any insight. syslog-10.24.1.10.log.txt tower-diagnostics-20230908-2003.zip
September 10, 20233 yr Community Expert 19 hours ago, regular-tract6433 said: between 18:35 and 19:48 on the 8th Nothing relevant logged here, but there are previous macvlan call traces so you should change the docker network to ipvlan.
