Problem after flash drive died
Hi
My flash drive broke yesterday so I've created a new one from an old backup. Now I have a problem with my cash hard drive. It says Unmountable: Unsupported or no file system. Under the file system it says btrfs, but I switched a while ago to ZFS. Can it be fixed without having to format the hard drive?
Solved by JorgeB
Unassign cache, start array, stop array, reassign cache, start array, current pool should be imported, if it's not post diags.
Thanks for the quick reply, it solved my problem
